Reviews indicate the ANT 751 picks up both UHF and VHF, and direction is important but not a huge issue.
With 150 degrees and 224 for most stations could I likely set a single antenna to get all channels?
Can this be set to work with 2 TV's (probably would not be used at the same time very often), or would a second antenna be required?
Thanks
