I've been fiddling with this for a while now. I started out with the antenna in the attic, which did not work reliably. One thing I noticed was that during cloudy weather the antenna needed to be pretty much level but during clear weather it had to be tilted upwards to get decent reception.
I then moved the antenna onto the roof, without a mast. This works a lot better but reception is still spotty during clear weather. I haven't tried tilting the antenna since it was moved to the roof.
Can anyone explain this behavior, and suggest a remedy? Would a different antenna help?
