Old 1-Mar-2014, 7:13 PM   #3
ragendem
Thank you for your reply!
The DB2e is the wrong (or incomplete) antenna for your situation as there two major stations in Jax that are on VHF, the PBS and NBC affiliates.
OK, how do I go about finding an antenna? I would like it to be 2 feet or shorter in height, work in the VHF and UHF frequencies, and less than $100.
Do you have a clear path, are you in a swamp with tall tees, behind some other taller buildings, etc.
Yes - clear path, no tall trees or buildings.
As for your attic, it has been observed that metal roofs and radiant barrier insulation are both quite common in your state. If you have either, that would effectively rule out the attic space.
I don't have a metal roof, and the attic is above the garage - no insulation near the antenna, or between the antenna and the stations.
ragendem is offline   Reply With Quote
