Old 1-Mar-2014, 6:47 PM   #2
Amazon reviews are usually a pretty lousy way to select an antenna since your antenna selection is all about you and your location. The DB2e is the wrong (or incomplete) antenna for your situation as there two major stations in Jax that are on VHF, the PBS and NBC affiliates.
Before recommending any antenna, we really need to know what the signal path looks like back in the direction of Jax. Do you have a clear path, are you in a swamp with tall tees, behind some other taller buildings, etc.
As for your attic, it has been observed that metal roofs and radiant barrier insulation are both quite common in your state. If you have either, that would effectively rule out the attic space.
