Old 1-Mar-2014, 6:00 PM   #4
For reception of the easy to receive Digital Broadcast Tv Stations/Channels with the Tv antennas at about 35 feet above ground.
WHAG-DT , Real UHF channel 26 , NBC.
WJAL , Real UHF channel 39 , IND.
WWPB , Real UHF channel 44 , Maryland , PBS.
W33CR-D , Real UHF channel 33 , Pennsylvania , PBS.
WWPX-DT , Real VHF high band channel 12 , ION.
W08EE-D , Real VHF high band channel , 8 , West Virginia , PBS.
WVPY , Real UHF channel 21 , Virginia , PBS.
W42CK , Real UHF channel 43 , Religion.
WHTM-DT , VHF high band channel , 10 , ABC and RTV Retro Tv Network.
WAZW-LD , Real UHF channel , 46 , Religion.
Above the Peak of the Roof in such a manner that reception is not being , obstructed , impeded , blocked , by the roof and building in the directions of , South West , North , North East , East.
Install a , Antennas Direct , DB8e UHF channels 14 thru 51 antenna aimed at about 217 degree magnetic compass direction.
And install a , http://www.antennacraft.net , Y10-7-13 , VHF high band channels 7 thru 13 antenna aimed at about 67 degree magnetic compass direction.
Install the , Y10-7-13 antenna about 3 feet below the DB8e antenna on the same mast pipe.
http://www.ronard.com/Tripods%200703/4712.html.
Use the , ronard(4712-50-10) , 10 foot tripod antenna mount.
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com.
Home Depot and Lowes have 10 foot long sections of , Top Rail , chain link fence Pipe that makes good antenna mast , the price is Low Dollars.
Install a , http://www.antennacraft.net.
10G221 preamplifier.
Connect the DB8e UHF antenna to the , UHF connection of the preamplifier.
Connect the Y10-7-13 antenna to the VHF connection of the preamplifier.
The FM radio trap switch will be in the , in/on position.
For Initial reception Tests have only 1 Tv connected.
Run a Continues length of RG-6 coax through a open door or window direct to 1 Tv.
The Tv Must Channel Scan for the , ATSC-Digital Broadcast Tv Stations/Channels , Antenna Channels , Air Channels.
WHSV-TV , UHF channel 42 , ABC , FOX , MyNetwok , Me-TV , At 217 Degree magnetic compass direction , is Very Weak Signal Strength , even at the 50 and 75 foot antenna heights , WHSV will most likely not be received or received reliably.
You can raise the antenna height with the Top Rail Pipe for Testing of reception.
With the 10 foot sections of Top Rail Pipe you can raise the antenna height higher , if required , above ground , and aim the DB8e antenna at about 68 degree magnetic compass direction to Test for reception of , WHP-TV , UHF channel 21.
Will need to rescan for channels.
Most likely , The stronger signal strength , WVPY UHF channel 21 , will interfere with reception of WHP , even though WVPY will be at a back angle to the DB8e antenna.
As always , trees and tree leave , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install antennas at a location that has least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building in the directions of reception.
The directions of reception at your location are , South West , West , North , North East , East.
