Old 28-Feb-2014, 9:12 PM   #3
Aim the , C2-V-CJM , antenna , at about 160 degree magnetic compass direction.
Buy at , http://www.amazon.com.
For reception of the Tv stations in the Green and Yellow reception zones.
A antenna system amplifier is not required.
For 3 Tv's connected use a simple common 3 way splitter.
The Tv/s Must Channel Scan for the ATSC-Digital Broadcast Tv Stations/Channels.
Go into the Tv Setup Menu and select ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~.
Some satellite systems will accept and distribute Tv antenna signals and some satellite systems Will Not.
If satellite service is discontinued.
Then to reduce problems with Tv antenna distribution , disconnect and remove all satellite system componets such as and not limited to , multi-swithces , multi-plexers , combiners , splitters , couplers , amplifiers , power inserters , power supplies.
Yes the satellite system coaxes can be used for the antenna system.
Last edited by teleview; 1-Mar-2014 at 4:55 AM. Reason: Clarify information and typos.
