WPMT Fox will not be received.
WHSV-TV Real UHF channel 42 , has , ABC , FOX , MyNetwork , Me-tv.
WHSV , signal strength is very weak at -7.2NM(dB) and has 2 Edge Path obstructions = reception path obstructions = hills/mountains.
To see if higher antenna height will improve WHSV signal strength please make and post 2 more tvfool reports , 50 feet , 75 feet , antenna heights.
WHP-Tv Real UHF channel 21 CBS is very weak signal strength and will not be received because WVPY Real UHF channel 21 PBS is a stronger signal and will override WHP.
With the increased antenna heights , perhaps WHP - CBS will be strong enough to receive.
And I can recommend a way to reduce and block WVPY - PBS.
Please make and post the 50 and 75 feet antenna height reports.
I can then make a recommendation.
Well I can make a recommendation now , however will be nice to see the higher antenna height tvfool reports and I can make a better recommendation.
Reason: Clarify information and typos.
