Thread: Help in WNY
Old 27-Feb-2014, 11:57 PM   #2
Looking at the Tvfool Current Plus Pending Applications Included Digital Radar Report And Channel List.
WNED-DT , Real UHF Channel 43 , virtual number (17.1) , PBS , is Very Weak Signal Strength
For reception of WNED and the stronger signal strength Digital UHF Tv Stations/Channels to the , North West and North.
Install a High antenna gain maximum reception antenna.
Antennas Direct , DB8e UHF antenna and aim both panels of the DB8e antenna at WNED at 335 degree magnetic compass direction.
Buy the DB8e at , http://www.amazon.com
For reception of the weak signal strength , WBBZ-TV , Real VHF high band channel 7 , virtual number (67.1) , ME-Tv , Raycom Sports , This Tv , Daystar.
Install a , http://www.antennacraft.net.
Y10-7-13 VHF high band channels 7 thru 13 antenna aimed at 290 degree magnetic compass direction.
Install a , http://www.antennacraft.net ,
10G221 preamplifier.
Connect the DB8e to the UHF connection of the Preamp.
Connect the Y10-7-13 to the VHF connection of the preamp.
Have the FM trap switch in the , in/on position.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
Install the , Y10-7-13 about 3 feet below the DB8e on the same antenna mast.
Home Depot and Lowes have 10 foot lengths of , Top Rail , chain link fence Pipe that makes good antenna mast , the price is low dollars.
Measure around the chimney and use a, ronard(2212) , ronard(2218) , ronard(2224) .
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions in the directions of reception including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antenna/s at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The Tv/s Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~.
Channel scan for the ATSC-Digital Broadcast Tv Stations/Channels.
Last edited by teleview; 28-Feb-2014 at 3:02 AM. Reason: Clarify information and typos.
