Old 27-Feb-2014, 7:00 PM   #3
The Tvfool radar report and channel list shows the Real Channel that is being transmitted and received.
The Current Tv channels that are being transmitted and received in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
KOMO is Real UHF Channel 38.
KING is Real UHF channel 48.
The UHF channel frequencies are short wave length and tend to be very directional and at a reception location this can create , Dead spots where the signal is low signal strength.
Moving the antenna up or down can move the antenna out of a dead spot.
And changing the aim of the antenna can also help with reception.
Trees and tree leaves , reflect (multi-path) , absorb , block , Tv reception , and some channels can be more effected then others.
Moving the antenna to a location that has less to no trees in the direction of reception will help with reception.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv' also have a Signal Quality Meter.
Signal Quality is important reliable reception.
If the Tv has a Signal Quality Meter , adjust and aim and locate the antenna for best signal quality.
Also , Digital Tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf.
Last edited by teleview; 27-Feb-2014 at 10:57 PM. Reason: Clarify information and typos.
