Antenna in Attic w/ internal home network panel
I recently purchased an antenna to install in my attic, w/ the plan to connect the coax cable to my cable feed. My issue is that I traced the cable from the external box, into the house, clear across the house, and into my internal network panel in my walk-in closet. I attempted to drop the coax cable from the antenna into the same spot where all the other cables were, but it is in the very corner of my attic so it's very tight and don't have direct visibility, or get directly over the hole that has been drilled. Any tips? Can I get access via the eaves/overhangs. Also, once I get the cable dropped, I have no idea where to plug it in since nothing was labeled when I purchased the house.
