Thread: Outdoor Antenna
Old 27-Feb-2014, 4:05 AM   #4
The Tv reception at your location are Very Weak Signal Strength for the groups of Digital Broadcast Tv Stations/Channels to the , South , South East.
And even weaker signal strength of the Digital Broadcast Tv Stations/Channels to the North West.
For reception of the a little stronger Tv stations to the , South , South East.
Above the Peak of the Roof install a , Antennas Direct , DB8e , UHF channels 14 thru 51 , antenna aimed at about 138 degree magnetic compass direction.
And install a , http://www.antennacraft.net , Y10-7-13 , VHF high band channels 7 thru 13 , antenna aimed at about 175 degree magnetic compass direction.
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com.
Install a , http://www.antennacraft.com.
10G221 preamplifier.
Connect the DB8e , UHF antenna to the UHF connection of the preamplifier.
Connect the Y10-7-13 , VHF antenna to the VHF connection of the preamplifier.
But the , HFS-2D and HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
http://www.antennacraft.net.
http://www.hollandelectronics.com.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The directions of reception at your location are , South , South East and North West.
The Tv's Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ ATSC Channels , DTV Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tuners will Automatic channel scan for cable tv channels.
Go in to the Tv Setup Menu and select , ATSC-Antenna Digital Broadcast Tv Stations/Channels.
Channel scan for the ATSC-Digital Broadcast Tv Channels.
You can Test reception of the North West group of Tv stations , aim both antennas at about 316 degree magnetic compass direction.
And Rescan for channels.
