Bought a converter box for the older TV. That comes in nice but, it is not HD. The HD flat screen's channel 8 audio problems are gone since a couple more double rescans. The audio clipping have moved to 69 FOX and think the antenna is just not robust enough. The antenna is aimed at 132 degrees magnetic which should pick up the broadcast without a problem. In addition to the RCA ANT751R, I added an Antennacraft 10G201 preamp. This antenna is coded for Yellow, Green, LT Green, and Red reception areas. I think i need one that includes Blue. Is there a known good antenna that should cover this requirement?
