Old 27-Feb-2014, 12:59 AM   #5
I recommend Test reception with a different antenna.
The cost is Low and I think reception will be improved.
I recommend remove the CS2V and install a ,
http://www.antennacraft.net , HBU11 antenna aimed at about 110 degree magnetic compass direction.
As always , the starting antenna aim direction is the -->starting antenna aim direction.
The antenna aim direction can be adjusted for best reception.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
As you now know , trees and tree leaves are disruptive to broadcast Tv reception.
The closer and bigger and thicker the trees the worse reception is , the more distant and small and thiner the trees are the better for reception.
Looking at the Tvfool radar map for the , Digital Current Plus Pending Applications Included Radar Map , your Main group of Tv stations is to the South East , with receivable Tv stations to the , East , North East , North , North West , West , South West.
I recommend find a location on your property that has the least amount to no amount of trees in the directions of reception.
Home Depot and Lowes have , 10 foot lengths of , Top Rail , chain link fence Pipe , that make good antenna mast and makes good mast for the antenna so as to move the antenna around on your property to find a good location for reception.
Connect a long continues length of coax to the HBU11 antenna and run the long continues length of coax through a open door or window direct to one Tv.
Digital Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf
Last edited by teleview; 27-Feb-2014 at 5:23 AM. Reason: Clarify information and typos.
