Old 26-Feb-2014, 9:05 PM   #1
MrBruce
Help with HDB8X antenna
First, here is my TVFool report.
http://www.tvfool.com/?option=com_wr...5b94821193f1d4
I have the following HDB8X antenna.
http://www.solidsignal.com/pview.asp?p=HDB8X&ss=38724
I have the antenna pointed towards 288 degrees True North, the direction of WTIC 31 real, WVIT 35 Real, WEDH 45 Real and WCCT 20 Real.
My attempt is to receive WFSB 33 Real, which is at 296 degrees of True North.
This antenna is designed to be pointed in two different compos directions at the same time.
At the moment, I have both sections pointed in the same basic direction, and although WVIT, WTIC, WEDH and WCCT come in, WFSB does not, this is basically because WFSB's broadcast tower is further north in the Farmington CT. area than WVIT.
Now my question is this, when aiming the two separate sections of the HDB8X, which angle is better? Positioning it so the top view of the "V' is set so both sections are facing each other or set so both sections are looking away from each other?
I have to set this thing up ahead of time because my antenna is on a 60 foot mast pipe on my roof and gaining access to the antenna once it is up there is not possible since I can not climb the poll.
Also has anyone else out there used this antenna and if so how do you feel about its performance?
Thanks in advance.
Bruce.
MrBruce is offline   Reply With Quote
