Old 26-Feb-2014, 4:57 PM   #1
churley79
Aiming Clearstream 2V in Garner, NC
Ok,just trying to get the best signal as possible (specifically on local channels CBS, NBC, ABC, etc..). I have a Clearstream 2V mounted on the roof, then hits a distribution amp and splits off to 3 rooms.
The local channel antennas are located down in Clayton in a cluster. However, ION is off by itself in a different county at a completely different direction. The area around my house has a lot of trees and there is a big old oak right in front.
With this as my readout:
http://www.tvfool.com/?option=com_wr...5b949b330c2eb6
What would be the most opportune direction to aim my antenna? And, would it be possible to get good signal (few dropouts) on both the local networks and ION? With prior experimentation it appears if I aim the antenna at ION it causes the local channels to randomly drop. If I aim it at the local towers, it causes ION to drop.
Sorry for being so long winded. Thank you.
churley79 is offline   Reply With Quote
