Old 26-Feb-2014, 9:47 AM   #7
arkay
That's an enviable reception report. With some experimentation re. location and orientation, indoor reception should be fairly easy to make reliable.
Not much issues with overall reception.. just some random signal disruptions.. which is why I started this thread
Originally Posted by teleview View Post
The main group of Tv stations are to the North East and the other group are to the West.
Put the FreeVision antenna in/at a ~North East~ facing window aim the antenna at about 54 degree magnetic compass direction.
Here is how to aim indoor and outdoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
If a long length of coax is required to connect the antenna that is in/at the window to the Tivo or TV , then so be it , because reliable reception is more important then objections to the long length of coax running through the living space.
Digital Tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf.
Looks from that link that I might need to point in the upward angle assuming my antenna is An All Band UHF-VHF-FM
I can't seem to find my compass, so I need to get one just to get the most optimal direction. When I get it, I'll reset it and try double scan.
Thanks!
arkay is offline   Reply With Quote
