I'm in the process of finishing up the grounding.
The problem is if grounding the antenna continues to reduce the signal strength I'll have to scrap the antenna project and go back to cable. There is a limited amount of tolerance from the better half I'll get over programs cutting out in the middle before we end up reconnecting cable.
