The Current Broadcast Tv Stations/Channels that are transmitted and received in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your location has receivable channels in All 3 Tv bands.
To help find the problem , the following information has to do with the DB4e - UHF channels 14 thru 51 antenna , and Y5-7-13 - VHF high band antenna.
And now a question about what weak signal strength Tv stations are not received when the ground wire is connected.
As examples.
KUVS-DT , Real UHF channel 18 , virtual number (19.1) UNI.
KXTV , Real VHF high band channel 10 , ABC
Also the coupler that connects the 2 antenna together on to one coax Must Be a , UVSJ = UHF/VHF Separator/Joiner.
Not a reversed UHF/VHF splitter.
Reason: Clarify information and typos.
