Old 25-Feb-2014, 7:33 AM   #4
Originally Posted by technicolor View Post
Sorry, maybe i wasn't clear. The hd1850 is outside pointed at new york and works great. The winegard will be pointed at philadelphia.
Which is why I suggest you test reception with it. You already own an antenna that has very similar performance to the 8200. If you haven't already spent money on the 8200, then temporally turning the existing HD1850 toward Philadelphia would inform your decision to buy or not.
If the HD1850 can't see the signals you're after, the 8200 is not likely do be much different. The two antennas are quite similar in capability.
