Originally Posted by stvcmty
FM is received best with an antenna designed for FM frequencies, 88 to 108MHz. The RCA ANT751 is designed for TV RF channels 7 to 13 and 14 to 51, 174 to 216MHz and 470 to 698MHz. The elements on the ANT751 are too short to offer any gain receiving FM stations.
Yeah, it was a shot in the dark tapping my ANT751 but it wasn't difficult. Previously I made a custom folded dipole optimized for 105.3 but it still had static. This was mounted indoors on the wall at the top of the ceiling and I was pretty disappointed when it did not work. The ANT751 test was just to see what the signals were like on my roof but since the static remains I think I've co-channel interference.
An antenna like the FM6 on a rotator would be better for FM radio. If you wanted an omnidirectional antenna, a FMSS would work, but it would have trouble with stations that have a co channel warning flag, because it would not offer any rejection for signals from unwanted directions.
I think the Omni would make things worse. I thought about putting my custom folded dipole on the roof and aiming its null right at 51/43 degrees where the co-channels broadcast.
Also, from the FM fool image you linked to, there are two strong signals on 107.7 within 66 degrees of each other. The first is KSAN, the second is KSAN-FM1. KSAN-FM1 is an on channel booster for KSAN, depending on how they are synchronized it is possible they could be adding destructively at your location.
I am working on a plan-b, or I could be has high as plan-e or f, but now that it is (possibly) co-channel interference I going to think about how to compensate for that. Thanks for the reply.
