Indoor reception is prone to difficulty. The signal is lower in strength due to the penetration losses caused by building structural materials. You also have higher levels of interference from sources inside the building (computers, motors, CFL and LED lighting products, etc.).
A larger, more directional antenna may help... If you could mount outdoors, the CS2-V should be a capable option. A Winegard HD7694P would not be overkill.
