Old 22-Feb-2014, 4:03 PM   #6
Desert Rat
Thanks for the help.
It's a bummer that Phoenix 10.2 RF26 is SD. I'm thinking now since Phoenix HD FOX10 is VHF that maybe I should go for Tucson FOX 11 on RF 25 since it sounds like deep fringe VHF is more difficult. But I know if I can get Tucson 11 at all it will likely need a preamp. And many of the other Tucson stations are very strong, so I'll probably have saturation issues with the preamp.
STVCMTY
Currently i am only running one TV but may want to add 1 or two more in the future. My cable length from the antenna on the roof is 30 ft of RG6 that connects to about 20 more feet of coax in the wall (30 yrs old, presumably RG59). No other ground blocks, splitters or combiners yet.
StephanieS
Thanks for the antenna recommendations. I could go with the two antennas as you suggest, and just use my rotator to swing from Phoenix to Tucson stations. Otherwise my plan was to just keep the attic antenna for Tucson stations and use a specialized rooftop setup for FOX out of Phoenix. If I go that route I will only need UHF or VHF, but not both depending on which FOX station I'm trying to receive (10 or 26).
Desert Rat is offline   Reply With Quote
