Old 22-Feb-2014, 4:58 AM   #2
If the antenna is a CS2 , without the VHF reception rods.
Then order and install the VHF rods reception kit from , http://www.antennasdirect.com.
Install the CS2 with the VHF reception rods kit , Above The Peak of the Roof in such a manner that the antenna has clear views that are not , obstructed , impeded , blocked , by the roof and building in the directions of , North West and East .
Aim the antenna at about 295 degree magnetic compass direction.
Use a Real And Actual magnetic compass to aim antenna.
The signal strengths are strong for the Tv stations to the North West and East , a antenna system amplifier will most likely not be required.
1 of the channels you have listed is 20.
I am thinking that it is KOFY-TV and not KSCZ-LD.
Last edited by teleview; 23-Feb-2014 at 5:17 PM. Reason: Clarify information and tyos.
