Old 22-Feb-2014, 3:38 AM   #6
Research shows that FOX will be received on WHSV-TV UHF channel 42.
http://en.wikipedia.org/wiki/WHSV.
What this means is.
The Networks , NBC , ABC , CBS , PBS , FOX , MyNetwok , Me-TV , ION , LWN Live Well Network , will be received with 2 antenna connected to 1 antenna system amplifier , for 1 down lead that can be connected to a splitter.
And No antenna rotation with a antenna rotator is required.
This is good because antenna rotation Is Not channel surfing friendly , must wait for antenna to rotate and their Will Be Domestic Situations about the direction the antenna is aimed.
So avoiding antenna rotation is Very Important.
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , buy the roof and building in all directions.
Install a , Antennas Direct , DB8e , UHF channels 14 thru 51 antenna , aim 1 panel at about 42 degrees magnetic compass direction.
Aim the other panel at about 224 degree magnetic compass direction.
Install below the DB8e antenna on the same mast.
Install a , http://www.antennacraft.net , Y10-7-13 , VHF high band channels 7 thru 13 antenna aimed at about 132 degree magnetic compass direction.
Install a , RCA TVPRAMP1R , preamplifier.
Connect the DB8e , UHF antenna to the UHF connection of the preamp.
Connect the Y10-7-13 , VHF antenna to the VHF connection of the preamp.
Operate the preamp in the Separate antenna mode.
Set the FM radio trap switch to the , in/on position.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
Measure around the chimney and use a , romard(2212) , ronard(2218) , ronard(2224) .
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com.
http://www.antennacraft.com.
http://www.hollandelectronics.com.
Home Depot and Lowes have , Top Rail , chain link fence Pipe , 10 foot lengths , that makes good antenna mast. The price is Low Dollars
Install the Y10-7-13 below the DB8e on the same mast about 3 feet apart.
