Old 21-Feb-2014, 8:16 PM   #3
The Phoenix Tv stations are 80 Pluse miles away , are very low signal strength and have 2 Edge path obstructions = hills and mountains.
For reception of what will be received from Phoenix.
A Big antenna is required.
Install a www.antennacraft.net , HBU55 antenna aimed at about 311 degree magnetic compass direction.
Install a , RCA TVPRAMP1R , preamplifier.
Connect to 1 Tv only , No splitters , for the Testing of reception of the Phoenix Tv stations.
For reception of FOX Tucson.
Install a NEW matching transformer (balun) to the UHF antenna and run a NEW coax form the New matching transformer through a open door or window direct to 1 Tv.
Tilt the front of the UHF antenna up and aim at the top of the mountain where the Fox transmitter is , scan for channels , is Fox received now??
Also can aim the UHF antenna at the surrounding mountains to find a mountain that provides a strong reflected signal of the FOX transmitter.
Also , Digital Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
www.wchstv.com/DoubleReScanAlert.pdf
Last edited by teleview; 24-Feb-2014 at 3:03 AM. Reason: Clarify information and typos.
