Old 21-Feb-2014, 6:21 PM   #2
Your first TV Fool report appears to be based on a default level of 10' AGL. I assume the terrain in your area is relatively flat... If so, I suspect conditions will be improved significantly just a few feet higher. Please consider running an additional report based on 25' AGL.
Even an indoor antenna should receive some signals... Have you used the TV's setup up menu system to change the tuner to 'air' or 'antenna' mode, and then run a full channel scan?
Based on the first report you've posted, I would suggest you use an outdoor mounted antenna like the Antennacraft HBU-44, aimed toward the south (and slightly east).
