Old 20-Feb-2014, 9:48 PM   #2
Attics and the Inside of Buildings Are Not a reception friendly environment and Never Will Be a reception friendly environment.
Begin the reception process with a antenna in the attic.
The HD7084P antenna has a little more antenna gain then the HD8200U antenna and is a little smaller in size.
Recommend install the HD7084P antenna in the attic aimed at about 250 degree magnetic compass direction.
250 magnetic compass direction is a in between aim direction of the groups of Tv stations to the West and South West.
____________________________________________
Install a , RCA TVPRAMP1R , preamplifier.
Buy the , HFS-2D and HFS-3D , splitters at , www.hollandelectronics.com , or , www.amazon.com
www.amazon.com
If reception situations/problems happen with the HD7084P antenna in the attic that are not resolvable with antenna aim and location adjustments in the attic then move the HD7084P antenna to Above the Peak of the Roof.
Here are some Above The Roof antenna mounts.
Use the , ronard(4569) , eave antenna mount.
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com
Last edited by teleview; 25-Feb-2014 at 5:19 PM. Reason: Clarify information and typos.
