Old 20-Feb-2014, 3:20 PM   #3
Install the , http://www.antennacraft.net , HBU11K antenna above the roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , South East and North West.
Recommend aim the HBU11K antenna at about 120 degree magnetic compass direction.
The reason for the 120 degree magnetic compass direction is , WZPX-DT , ION Tv , the signal strength is weak and the 2 Edge path obstructions = hills and mountains in the reception path.
Directional antennas such as and not limited to the HBU11K antenna , receive the best in the forward direction , and also receive at , front angles , back angles , and back of the antenna.
Directional antennas such as and not limited to the HBU11K antenna receive the least amount of signal directly on the sides of the antenna.
As always , trees and tree leaves , plants and plant leaves , buildings and other obstructions including your own roof and building have a Negative Effect on reception.
Absorbing and Blocking Reception.
The Best Practice for reliable reception is to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
