Old 20-Feb-2014, 2:53 AM   #1
russhg
Need recommendation for rooftop antenna
I am currently using a rooftop mounted Winegard 6065 antenna with rotor for FM dxing. I am planning to cut my cable connection and need to replace that antenna with one that will pull in as many HD channels as possible while still getting good FM reception. My antenna is between 25 to 30 ft high but I'm surrounded by trees on the north and south. I recently found TV Fool while trying to research antennas and was impressed with the recommendations given to others. Now I would like to enquire from your great knowledge base what would be my best setup. Here's a link to my tvfool report.... http://www.tvfool.com/?option=com_wr...5b94e23ef1cf34
thanks for your help, Russ
russhg is offline   Reply With Quote
