Old 19-Feb-2014, 11:24 PM   #1
ceggar
antenna buying help
I was hoping to get some help buying the right antenna. I currently have a dish antenna hooked up and I would like to disconnect that and hook up an antenna. I want to split to 3 tvs. The run from the antenna to inside the house where it will split is aprox 135'. Antennaweb says a medium range with a pre amp. I kind of question that. There is a lot of trees. A local electronic store sells a channel master CM 3016, and a cm 3018 that would be easy to take back. Thanks for your help.
http://www.tvfool.com/?option=com_wr...5b949c753207c9
ceggar is offline   Reply With Quote
