Old 19-Feb-2014, 6:11 PM   #7
The Tv/s Must Channel Scan for the , ATCS-Digital Broadcast Tv Stations/Channels.
DO NOT channel scan for -Only- Analog channels.
DO NOT channel Scan for cable Tv channels.
The Repeater/Translator Tv transmitters are to the South West and West.
Here is information of the Digital Broadcast Tv Stations/Channels.
http://www.rabbitears.info/market.ph...allsign=125434
And here is some information I found about KENY-LP , UHF channel 39.
It looks like KENY is transmitting a Analog signal and has a application to transmit Digital.
http://en.wikipedia.org/wiki/List_of...One_affiliates.
http://www.livestream.com/kenytv
K32IK-D , UHF channel 32 , KTSC , PBS.
K49LW-D , UHF channel 49 , KOB , NBC and This Tv.
Are Very Weak signal strength.
And the other Digital Broadcast Tv Stations/Channels on up the channel list are Weak signal strength.
As a , Positive , the tvfool report is showing all the Tv stations as being LOS=Line Of Sight - Reception.
The receivable Digital and Analog Broadcast Tv Stations/Channels.
The Current UHF TV channels that are transmitted and received in the , USA , Canada and Mexico are , 14 thru 51.
Recommend install a UHF antenna that will have Maximum reception ability.
Install a , Antennas Direct , DB8e antenna.
Above the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building , install a , DB8e antenna aimed at about 211 degree magnetic compass direction.
For 1 or 2 Tv's connected a antenna system amplifier will most likely not be required.
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com.
Home Depot and Lowes have , TOP RAIL , chain link fence , PIPE , that works well for antenna mast/pipe. The price is Low Dollars.
The tvfool report is showing that all the receivable Tv channels are , ATSC-Digital Broadcast Tv Stations/Channels.
Except for 2 Analog Broadcast Tv Stations , KENY UHF channel 39.
And K51DM channel 51 , SON LIFE , a religion network.
As you can see , the Tvfool Digital Current Plus Pending Applications Included Tvfool Radar Report and Channel List shows all of the receivable Tv stations in 1 direction South West , except for KENY channel 39 , that is to the West at 268 degree magnetic compass direction.
If KENY is not reliably received with both reception panels of the DB8e antenna aimed at the main group of Tv stations to the South West , then aim 1 of the reception panels of the DB8e antenna more in the direction of KENY.
Last edited by teleview; 27-Aug-2014 at 2:55 AM. Reason: Clarify information and typos.
