Old 18-Feb-2014, 5:51 PM   #1
caucapon
Most Effective Installation Method
I am trying to ascertain what installation method would serve me best. In another thread, I received advice regarding appropriate antennas for my situation. If I decide to go the high ticket and probably safest route, I'll use one DB8e (12 lbs.) and one CS600 (3 lbs.).
I live in a retirement community (HOA) rancher with its peak 16.5' above ground. Reception is primarily two edge until the antennas are elevated to 20'. At 23', all critical stations are LOS. There is the possibility that I'll need to go that high to assure good and reliable reception. I am aware that even 23' might not be enough, despite my TVfool's 23' report,
http://www.tvfool.com/?option=com_wr...5b94e9e5ca5e74
Assuming that I need to elevate 7', should I
- simply pick up a 10' mast and an eave installation kit
- Purchase a 5' tripod and 5' mast
- Buy a 30' telescoping mast to be used from the ground up
- Use some other method of your choosing?
As is the case with many, I am hesitant to put holes into my roof, even using 2x4 extensions under the installation bolts.
While the eave mounting system is inexpensive and relatively simple, I am suspicious of its ability to within 70-80 mph winds, particularly because they tend to come in over the pond located behind us. There is nothing there to limit that wind's force.
The telescoping answer seems safest. It is, however, the most in-your-face method where neighbors are concerned.
In reading various threads, blogs, etc. regarding antenna installation methods, I've been struck by how variable opinion is. Instructions on Denny's site indicate that tripod installs are the most popular and most stable. Many others generally advise against using tripods at all. Some feel that simply placing a ground-based mast on a surface-level brick/stone is all that's needed; others state that a 2' to 4' hole filled with concrete is the only way to go. Etc., etc. In the end, almost everyone seems to get his/her antenna up one way or another.
Any wise comments based on experience would be appreciated.
Al
caucapon is offline   Reply With Quote
