Old 17-Feb-2014, 11:20 PM   #3
Originally Posted by roanman View Post
Ichan 11 is rock solid and 5 comes and goes. here is my signal analysis:
Suggestions and comments would be appreciated.
The signal from channel 5 is plenty strong. Your real problem is that WCYB and WJHL come from different directions than the other stations and your antenna may not be aimed at NBC and CBS.
Assuming that channel 5 works with the antenna aimed properly, the best solution is to use your existing antenna for 350 degrees and add a 4 bay UHF only antenna aimed at about 125-130. Add the two antennas together with a TVPRAMP1R preamp.
If WCYB remains iffy with the antenna aimed right, try different antenna heights or consider interference on low band.
