Old 17-Feb-2014, 3:05 AM   #2
For following recommendation , the Antenna Craft 5884 is used only for reception of channels 5 and 11.
Aim the Antenna Craft 5884 antenna at Tv stations 5 and 11.
The receivable Digital Broadcast Tv Stations/Channels to the North are VHF channels 5 and 11.
Recommend aim the 5884 at about 359 degree magnetic compass direction.
If the Antenna Craft 5884 does not provide reliable reception of channel 5.
Then step up to a Winegard HD5030 VHF channels 2 thru 13 antenna.
The HD5030 has been discontinued , however it looks like , www.warrenelectronics.com , has some in stock.
The tvfool radar report and channel list is showing that the receivable Digital Broadcast Tv Stations/Channels to the South East are All Real UHF Channels.
The Current Real UHF channels are , 14 thru 51.
The Tvfool radar plot and channel list shows Real Channels and the (virt) Virtual numbers , the virtual numbers are not real channels , even if the virtual number is the same as the Real Channel.
For Maximum reception of the , Weak Signal Strength , UHF Tv stations/channels to the South East.
Aim a , Antennas Direct , DB8e UHF antenna at about 125 degree magnetic compass direction.
Install a , RCA TVPRAMP1R preamp.
Test reception with the FM trap , off and on.
Operate the RCA preamp in the Separate antenna mode.
Connect the 5884 or HD5030 antenna to the VHF connection on the RCA preamp.
Connect the DB8e antenna to the UHF connection of the RCA preamp.
Here are some Above The Peak Of The Roof antenna mounts.
http://www.ronard.com/Tripods%200703/4712.html.
Use the , ronard(4712-50-10) , 10 foot tripod antenna mount.
Measure around the chimney and use a , ronard(2212( , ronard(2218) , ronard(2224) .
http://www.warrenelectronics.com
http://www.amazon.com.
http://www.ronard.com.
Home Depot and Lowes have , Top Rail , chain link fence pipe 10 feet long , that makes good antenna mast. And cost Low Dollars.
Digital Tuners can develop -Digital Glitches_ that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf
Last edited by teleview; 22-Feb-2014 at 7:03 AM. Reason: Clarify information and typos.
