Old 15-Feb-2014, 11:30 PM   #8
This Reception recommendation is based on the provided tvfool reports.
This reception recommendation is based on several recent question askers have come here with reception problems receiving , KFMB-TV Real VHF high band channel 8 CBS , and , KGTV-DT Real VHF high band channel 10 ABC.
And the continuing reception situations/problems receiving the San Diego Tv Stations.
And the Fact that the Federal Antenna Law says Yes you can install Tv antennas above the roof so as to have reliable reception.
http://www.fcc.gov/mb/facts/otard.html.
Above the Peak of the Roof install a , Antennas Direct , DB8e , UHF channels 14 thru 51 antenna.
Aim 1 panel at about 145 degree magnetic compass direction.
Aim the 2nd panel at about 175 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antennas.
For reception of the reported problems of reception of , KFMB and KGTV.
Install a , Antenna Craft , Y10-7-13 , VHF high band channel 7 thru 13 antenna.
Aim the , Y10-7-13 antenna at about , 193 degree magnetic compass direction.
Install a , Antenna Craft , 10G221 preamplifier.
Connect the DB8e antenna to the UHF connection of the preamp.
Connect the Y10-7-13 antenna to the VHF connection of the preamp.
Buy the , HFS-2D , HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com.
Home Depot and Lowes have , 10 feet Top Rail , chain link fence pipe that make good antenna mast. The cost is low dollars.
Install the , Y10-7-13 antenna below the DB8e antenna on the same mast
Separate the Y10-7-13 and the DB8e antennas by about 3 feet on the same mast.
http://www.antennacraft.net.
http://www.hollandelectronics.com.
Digital Tv Tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf
