Old 15-Feb-2014, 7:30 AM   #6
Here is the Federal Antenna Law that says Yes you and every one can install a Broadcast Tv Antenna of Any Size Above The Peak Of The Roof so as to have Reliable Reception.
Hoa's are well aware of the Federal Antenna Law.
And some Hoa's are thinking your are not aware and even if you do become aware of the Federal Antenna Law , you will not understand the Federal Antenna Law.
That the Federal Antenna Law says Yes you can install Broadcast Tv Antennas of Any Size Outside Above The Peak of the Roof in such a manner so as to have Reliable Reception , and you do not have to hide the antenna and you do not have to contact the Hoa.
You do not have ask the Hoa for permission or even contact the Hoa about installing a Broadcast Tv Antenna above the roof so as to have Reliable Reception.
www.fcc.gov/mb/facts/otard.html
http://www.fcc.gov/guides/over-air-r...n-devices-rule
Last edited by teleview; 17-Feb-2014 at 12:20 AM. Reason: Clarify information and typos.
