Old 27-Jan-2010, 5:51 AM   #5
bigbangbaby
Awesome! Thanks for the speedy response!
I had a feeling that there was a problem with my antenna since, after reading a lot of the posts here, people that set up "attic" antennas seem to get a lot more channels than I do. I'm going to take your advice and replace the antenna that I currently have but I seem to be having problems locating the antenna you suggested (Winegard HD7696P) in the Toronto area.
From what I've read, a lot of people in Toronto are having a lot of success with the Channel Master 4221/4228HD set up in their attics. Do you have any opinion on this antenna? I know it's not the same as the one you suggested but @ least I can pick it up @ a nearby store here.
Here are the specs:
The Channel Master 4 Bay Antenna is a high quality UHF HDTV OTA Antenna optimized for DTV (Digital TV). Its not as big as its big Brother the 8 bay channel master 4228 and 4228HD with its 8 bays.
Channel Master's model 4221HD antenna can receive digital and analog over-the-air TV signals in the UHF band only (over 90% of digital TV signals are in the UHF band). The 4221HD is optimized for "near-fringe" reception of HDTV. Its space-efficient design is suitable for roof and attic installations. Channel Master 4221HD is said to have a higher gain then the original 4221.
The Channel Master 4221HD is classified as a Medium-sized Directional antenna. For Over the Air channels see our OTA page for channel listing by postal code within Canada or the USA.
Details:
- receives digital & analog UHF TV signals
- range is 45 miles
- reception "beam width" is 45 degrees
- 4-bay bowtie dipole design
- 20"W x 5-1/4"D x 36-1/4"H
- 10" turning radius (if used with an antenna rotor)
- includes 300-ohm-to-75-ohm adapter
- mast not included
- RG-6 cable is recommended
- 10 inch Turning Radius
- Far Suburban Rated
- This is a Large Directional antenna and yields a beam width of about 45 degrees
- Box size: L 37.5" H 21.5" W 5.5"
Thanks again for all your help! You've been amazing!
BBB
bigbangbaby is offline   Reply With Quote
