Old 14-Feb-2014, 4:11 PM   #2
Above the Peak of the Roof install a , Antennas Direct , DB8e , UHF channels 14 thru 51 antenna.
Aim one panel at about 302 degree magnetic compass direction.
Aim the other panel at about 224 degree magnetic compass direction.
Can buy the DB8e antenna at , http://www.amazon.com.
Here is how to aim antennas.
Above the Peak of the Roof install a , Antenna Craft , CS600 , VHF channels 2 thru 13 antenna aimed at about 302 degree magnetic compass direction.
http://www.antennacraft.net.
Install a , Antenna Craft , 10G221 , preamplifier.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
Use the , ronard (4560) , eave antenna mount.
Measure around the chimney and use a , ronard(2212) , ronard(2218 , ronard(2224) .
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com.
AS always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building in the directions of reception.
Absorbing and Blocking Reception.
To have Reliable Reception , the Best Practice is to install antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The directions of reception at your location are , West and South West.
The TV's Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ ATSC Channels ~ DTV CHannels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~.
Channel Scan for the , ATSC-Digital Broadcast Tv Stations/Channels.
Last edited by teleview; 15-Feb-2014 at 4:34 PM. Reason: Clarify information and typos.
