Old 14-Feb-2014, 1:18 AM   #2
Please make and post a Tvfool report , use the Exact address to make the report and make the antenna height on the report 25 feet above ground.
If the Excat address does not work then go to the Tvfool home page and click on >>Start Maps<< , enter the zip code and move the pointer on the map to the Exact reception location.
Make the antenna height in the report 25 feet above ground and post the report.
What is the make and model number of the antenna??
If make and model number not known then what antenna in the picture looks the most like the anten a you have??
www.kyes.com/antenna/pointing/pointing.html
