Start with making and posting a Tvfool report for the reception location.
Go to the Tvfool home page and click on , >>Start MAPS<< ,
Use the Exact address to make the report.
Make the antenna height in the report 25 feet above ground.
Also make and post 2 more reports with antenna heights of 40 and 60 feet antenna heights above ground.
If the Exact address does not work to make the report.
Then use the zip code as a starting place , and move the pointer on the map to the Exact reception location and make and post the reports with antenna heights of , 25 , 40 , 60 , feet antenna heights above ground.
