Old 13-Feb-2014, 3:08 PM   #2
Install 1 Antenna.
Directional antennas such as and not limited to the ANT751 antenna receive the best in the , forward direction , a little less at front angles to the antenna , less at back angles to the antenna , less at the back of the antenna.
Directional antennas such as and not limited to the ANT751 antenna receive the least amount of signal directly on the sides of the antenna.
Small directional antennas such as and not limited to the ANT751 antenna have a small amount of signal gain at the front of the antenna and also receive at angles to the antenna.
The bigger larger and more reception elements a directional antenna has , the more signal collecting ability the directional antenna has and receives more signal at the front of the antenna.
And directional antennas also receive at angles to the antenna.
Most of the signal strengths are strong at your reception location.
--->Instal and connect 1 ANT751 antenna <--> Above the Peak of the roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in All directions.
Aim the ANT751 antenna at about 30 degrees magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
30 degrees magnetic compass direction as a starting aim direction because the most amount of the stronger signal strength Tv stations will be at the front and angles the the antenna.
You will be Suprised at how many Tv stations are received.
Avoiding obstructions of all types and kinds is Important for reliable reception , avoid the obstructions of trees in the directions of reception , avoid any and all other obstructions in the directions of reception.
Digital tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
www.wchstv.com/DoubleReScanAlert.pdf
Last edited by teleview; 17-Feb-2014 at 9:56 PM. Reason: Clarify information and typos.
