Old 13-Feb-2014, 4:53 AM   #2
The situation/problem is the antenna Is Not the correct antenna.
The situation/problem is as the temperature goes up and down propagation of the electromagnetic waves of the Tv signal are effected by temperature inversions and reversions of air layers and sky.
This is Always happening to some degree every day and night every where over the planet.
You can find more information by typing , dx tv reception , in the google and yahoo search box.
Also water that gets into outside coax and connections and devices is a cause of bad reception
The Tv signal strengths at your location are Weak.
And your reception location and the antenna height of Tv fool report is showing , 2 Edge path obstructions = valleys , hills , mountains.
And the trees are , Zero help , and obstruct reception.
For better reception that compensates for the Negative Variables of your reception situation , a better antenna and better location for antenna is required for more reliable reception.
Use NEW Coax outside that has the compression type connectors on the ends of the coax.
Coax and couplers of all types and kinds can be bad , recommend replace with New.
Recommend install a , www.antennacraft.net , HBU44 antenna aimed at about 178 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Install a , www.antennacraft.net , 10G201 preamplifier.
Buy the HFS-2D and HFS-3D splitters at , www.hollandelectronics.com , or , www.amazon.com .
Install the , HBU44 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the direction of reception including trees and trees leaves , and obstructions of your own roof and building and any other type or kind of obstruction in the direction of reception.
To that end , here are some antenna mounts.
www.ronard.com/909911.html
www.ronard.com/Tripods%200703/4712.html
Use the , ronard(4812-50-10)
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com , or , www.amazon.com .
Here are some places to buy antennas and etc.
www.amazon.com
Last edited by teleview; 13-Feb-2014 at 3:19 PM. Reason: Clarify information and typos.
