Old 13-Feb-2014, 1:33 AM   #2
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Some and not all Negative effects are.
Absorbing and blocking reception.
The Best Practice is to install the a antenna at a location that has the least amount to no amount of obstructions of any type or kind on the directions of reception including your own roof and building.
The Tv signal strengths are weak to very weak at your reception location and most have 2 Edge Path Obstructions = hills and mountains in the directions of reception.
For reception at your location install above the peak of the roof in such a manner that the roof and and building are not , obstructing , impeding , blocking , reception to the , North West , South West , South East , East , North East.
Install a , www.antennacraft.net , HD1850 All channel antenna aimed at about 345 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Install a , www.antennacraft.net , 10G201 preamplifier.
Buy the , HFS-2D , HFS-3D , splitters at , www.hollandelectronics.com , or , www.amazon.com .
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
www.ronard.com
www.amazon.com
The Tv's Must Channel Scan for the , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~.
Channel scan for ATSC-Digital Broadcast Tv Stations/Channels.
Digital tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
www.wchstv.com/DoubleReScanAlert.pdf
Test reception using a Continues run of New coax from the preamp unit at the antenna location , run the coax direct to 1 Tv.
No splitters.
All parts of the satellite Tv system such as and not limited to , multi-switches , multi-plexers , splitters , couplers , amplifiers , power injectors , power supplies , and etc, must be disconnected and removed.
Yes the coaxes that we're used for the satellite system can be used for the antenna system.
The Current Tv channels that are being transmitted and received in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your location has receivable Broadcast Tv Stations/Channels in all 3 Tv bands.
Install the Antenna Craft , HD1850 All channel antenna.
I Never recommend the Stacker.
The Stacker is designated to receive channels 7 thru 51.
Not VHF low band channels 2 thru 6.
And even so I still Never recommend the Stacker.
