Old 12-Feb-2014, 10:44 PM   #1
Apoculos
Antenna setup help: Oxford, MS
http://www.tvfool.com/?option=com_wr...5b9409317bee25 <- signal analysis
Hi everyone. I am cutting the cord and getting rid of direct tv! I am in need of some help. Above is the link to my signal analysis.. here is my setup and description of the problems I’m facing.
I have an HD Stacker Antenna(http://www.dennysantennaservice.com/...enna-html.html) with a Winegard LNA-200 Boost XT amp(http://www.amazon.com/Winegard-LNA-2...ywords=lna+200). Currently the antenna is about 18 feet in the air with 100 feet of coaxial cable(straight run no splitters or anything).
I’m basically right in the middle of Memphis, TN(338-346 degrees) and Tupelo, MS(151). I’d prefer to get all the Memphis channels cause there is more offered (bigger city). With the antenna plugged straight into the tv I can get most of the major networks(not ABC for some reason even though I get CW which comes from the same place) from Memphis, TN though they are prone to dropping out. If I turn it toward 151 I get a few of the channels from Tupelo, MS(ABC!/NBC) and still somehow get the Memphis NBC. When I do a scan with the antenna plugged into the amp with the pre amp plugged in the wall I get NOTHING from either direction. When I do a scan with the pre amp unplugged from the electricity I am able to get one channel (Memphis fox WHBQ-TV). I have recently gotten new RG6 cable and correctly installed compression f connectors just to be able to eliminate that as a potential problem. I have tried adding a 2 way splitter in case I’m “overloading” but that didn’t help at all.
Only ideas I have is maybe I got the wrong amp for my needs? Or maybe I need to add a bigger splitter if I’m in fact causing overload?
Look forward to hearing from you all and hopefully you can help me dump the dish once and for all!
Apoculos is offline   Reply With Quote
