Old 12-Feb-2014, 7:48 AM   #2
A Simple reception situation , above the roof install a , www.antennacraft.net , 5884 , All channel antenna aimed at about 133 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
A simple antenna mount , a Winegard DS3000 , J pole type antenna mount will work well with the , 5884 Antenna Craft antenna.
www.amazon.com
The reception signal strengths are strong at your location are LOS=Line Of Sight , reception is easy.
A antenna system amplifier is not required.
For 3 Tv's connected use a simple common 3 way splitter.
