Old 12-Feb-2014, 7:00 AM   #2
Above the Peak of the Roof install the CM4228HD antenna aimed at about 190 degree magnetic compass direction.
Here is how to aim antennas , www.keys.com/antenna/pointing/pointing.html
Install a , www.channelmasterstore.com , CM7778 preamplifier.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , www.hollandelectronics.com , or , www.amazon.com .
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com , or , www.amazon.com .
www.amazon.com
www.ronard.com
As always , tree and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
Multi-Path reflecting Tv Signals Bouncing All Around.
The Best Practice is to install the CM4228HD antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The directions of reception at your location are , South West , South , South East.
