Old 11-Feb-2014, 5:45 AM   #2
--->As Always<--->trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
Some and not al Negative Effects are.
Absorbing and Blocking Reception.
The Best Pratice is to install the ANT751 antenna at a location that has the least amount to no amount of obstructions of Any Type or Kind in the directions of reception including your own , attic , roof , building.
The Main Group of Tv transmitters is/are to the , South South West.
Aim the ANT751 antenna at about 195 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
As Always , the starting antenna aim direction is the ---> starting antenna aim direction.
The antenna aim direction and location can be adjusted to have the best reception.
Most Digital Tv's have a , Signal Strength Meter , and some Digital Tv's also have a , Signal Quality Meter.
Signal Quality is Important.
Home Depot and Lowes have 10 foot sections of , Top Rail , chain link fence pipe , that can be put together to get the ANT751antenna up high and the antenna can be walked around , probing for a location that has the best reception.
Their are No antenna system amplifiers or magic antennas that can , power through trees and other obstructions.
You can Test reception with a better antenna , Test reception with a , www.antennacraft.net , HBU44 antenna.
Even so , the HBU44 antenna is not used to , power through trees and other obstructions.
The Best and Most Reliable Reception happens with No Obstructions in the directions of reception
Use a , New Continues length of RG-6 coax , run the New Continues length of coax through a open door or window direct to 1 Tv to Test reception.
Digital tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
To clear tuner do , Double Rescan.
www.wchstv.com/DoubleReSacanAlert.pdf
