Old 10-Feb-2014, 4:04 PM   #4
Above the Peak of the Roof install a , www.antennacraft.net , HBU44 antenna with a , Antenna Craft 10G201 preamplifier aimed at about 170 degree magnetic compass direction.
Buy the , HFS-2D , 2 way splitter at , www.hollandelectronics.com , or , www.amazon.com .
www.ronard.com909911.html
www.ronard.com/Tripods%200703/4712.html
Use the , ronard(4712-50-10) , 10 foot tripod antenna mount.
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com , or , www.amazon.com
Absorbing and Blocking Reception.
Multi-Path Reflection Tv Signals Bouncing All Around.
The Best Practice is to install the HBU44 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
Some Digital Tv's will Automatic by Default channel scan to cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels~ .
Channel scan for the , ATSC-Digital Broadcast Tv Channels.
