Old 10-Feb-2014, 2:53 PM   #4
tonyp063
Are you looking to get the Baltimore station too?
I'd start with an Antennas Direct Clearstream 2V (*not* the 2) because it has hi-vhf capabilities that you will need for DC 7 & 9 & Baltimore 11 & 13.
http://www.antennasdirect.com/store/...V-Antenna.html
Aim it at magnetic 60 degrees, which will put the DC towers in a strong backside lobe
see the pattern at
http://www.antennasdirect.com/cmss_f...%2BVHF-TDS.pdf
Test it with 1 run of known good cable to 1 tv to start.
If you are going to feed 4 tv's , you will probably need some form of amplification to overcome cable loses.
The RCA TVPRAMP1R is well thought of, and seems to handle the potential for signal overload quite well.
tonyp063 is offline   Reply With Quote
