Old 10-Feb-2014, 3:33 AM   #2
A Simple reception situation.
Above the Peak of the Roof so that reception is not , obstructed , impeded , blocked , buy the , attic , roof , building , in the direction of , North West.
Install a , www.antennacraft.net , HBU11K , antenna aimed at about 343 degree magnetic compass direction.
The reception signal strengths are strong.
A antenna system amplifier Is Not required.
For 4 Tv's connected use a simple common 4 way splitter.
Absorbing and Blocking Reception.
Multi-Path Reflecting Tv Signals Bouncing Around.
The Best Pratice is to install the HBU11K antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The Tv's Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Reception , often named the ~ Antenna Channels ~ DTV Channels ~ ATSC Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ Antenna Channels ~ DTV Channels , ATSC Channels ~ Air Channels ~.
Channel Scan for the , ATSC-Digital Broadcast Tv Stations Channels.
